VrayProxy + Multi/Sub Materials
Hi everyone,
I can’t figure out how to export several models as a merged proxy with “create multi/sub-object material”
When selecting all models export them as a single file and reimport the proxy, picking the material I get always:
“the first object has no material”
What’s the trick or the best procedure…?
thx, thomas
are you using " automatically create proxy" to place it back in your scene replacing the original?
if you create a proxy on disk and load it manually, it wont have a material, since the material is not stored in the proxy file.
you should use “automatically create proxy”
…oh no…that’s a good hint! I will try this…thx super gnu!
