Vrayproxy not working with opacity ?
I’m converting a bunch of trees to vrayproxies.
I noticed that in the vrayproxies the leaves do not render at all. It turns out that if I disable the opacity on those, then they’ll render. Is this a limitation of vrayprocies ?
Using V-Ray 3.00.07
No, it’s not a limitation - works fine for me. If you have a scene where it doesn’t would be best to send it to support@chaosgroup.com so that the support guys can tell you what to do.
Ok, took me a whole day to figure out that it was due to “Force first map channel” being activated by default. Turning this off fixed all of my proxies.
Ok then. This is turned off by default in newer builds.
Really ? I never been happier to see such a little thing implemented in a new build then :slight_smile: Thank you !
