VRayRhino 2.00.239 - Matte Shadow does not work?
Matte shadow of Wrapper Material does not work.
What is wrong?
Useing V-Ray 2.0 for Rhino (Public build 2.00.239) + Rhino 5 64bit
scene file is attached.
matteshadowtest.zip (185 KB)
Hi
This is the second time I’ve seen this, but I haven’t figure out why this is The problem seem to be the floor surface. I just created a new floor surface and everything worked fine.
Can you tell me a little bit more about the floor surface of any special workflow that you are using? How you saved the scene?
Best
as you indicated, the plane was created newly, its worked. h’mmmm
I am investigating how to make this strange plane.
will report, if it can discover.
Thanx
the wrapper is working with the same behavior for me in the latest NBuild I have VRayForRhino5x64-2.00.24061
I create the new plane and works. Strange thing is that I made a scene with a previous version of the NBuild and re rendered and worked with out having to make again the Srf. Floor.
I also experience some strange behavior - it works but looks strange - as some light came from below of the object. I tried all settings of the wrapper material, created new floor surface and new matte material, with no results.
Any hints how to solve the problem?
Jakub
matte_bug.zip (1.64 MB)
I solved the problem by creating everything exept the washbasin model and material from scratch. Now it works fine. I guess the bug was caused by lights created in the older version of V-Ray.
