Vraysky -- visible to reflect but not camera?
I want to render the static portion of an animation with Vraysky -- no problem.
Then I want to render the animated objects only for compositing into the background. I want to render the animated objects on a black background so the alpha channel is clean.
How can I set the vraysky to be visible in the animated objects reflections but not be visible to the camera?
hmm leave max environment black and set vray environment to have vray sky…nothing special about that?
okay right. It’s been a while since I used a vray env map. I basically forgot it was there.
thanks.
