VraySoftBox problems
Hi Vlado.
I found a problem when i use Vraysoftbox in Vraylight and VrayRT.
Every time i put this map into the light, VrayRT stop working.
I have four licences and i found this problem in every pc.
software max 2011.
Regards.
I’m not sure but I’ve read that VraySoftBox is not compatible with VrayRT…
mmm… it is not very usable… a map like VraySoftBox can help so much in previz with vray RT.
I saw in Arezzo ( Italy) the presentation of this new map and I think it worked with RT.
I think to remember Nikki Candelero showing realtime changes… maybe i’m wrong..or maybe he Had a better version :)…
it doesn’t work with rt yet, as already pointed out in the other softbox thread:
http://www.chaosgroup.com/forums/vbulletin/showthread.php?66726-Vraysoftbox&p=539485#post539485
as vlado mentioned, the feature seems to have been slipped in the official build a bit ahead of schedule, that’s probably why it’s not fully supported yet.
ok. thanks Rivoli.
And sorry for my stupid questions. Maybe i made some errors in searching the word Softbox in the forum.
Regards
Will see if I can put this in for the next hotfix.
That would be great! - and if the directional parameter of the vray light gets in too then it will be a complete and pretty robust real-time lighting system :slight_smile:
