VRayToon as vector?
First off all: Thanks Chaosgroup for the Toon option! It is just great! Easy to use and most important absolut perfect quality for outline renderings!
Is there any way for you to write some vector output for Toon?
Cheers,
Lars
Unfortunately vector output is not that easy; it is on the “to do” list and we will look into it, but I don’t know if we will be able to implement this.
Okay, thanks for the reply. I’ll keep the fingers crossed!
Nevertheless VRayToon rocks!
Here is a trick:
1- Make the Render as big as possible
2- open in illustrator
3- use live trace function
Thanks Fraggle.
Your workflow unfortunately works not for every project. But at least it is another way.
