Probably i’ve found a bug when i use camera clip planes and vraytoon.
The problem is that objects which stay external to clip planes are rendered as black object and are not “cutted” from image.
If you turn OFF vraytoon all rendered as expected.
This problem appear with vraycamera as standard camera.
Vlado, what do you think??
Can you check if in SP1 this is corrected??
Riccardo
