Hey,
the ScannedMtl needs UV coordinates for the objects it is assigned to, which is fine.
However, often we get data from the clients that has no UV. Because this is highly tesselated CAD geometry, unwrapping is very hard. Often I resort to UVW map in box mode as a quick fix, which works fine for most materials (carpaint, rubber, plastics with grain, metals). But it came to my mind that the TriplanarTex might work even better, because it blends the seams of the box map. Is it possible to somehow integrate the TriplanarTex into the ScannedMtl for this purpose? I have no idea if this is a good idea at all, because I remember Ivaylo talking about anisotropy, which seems to be very picky about UV coordinates.
yes, the anisotropy is really sensitive about the uv mapping, btw if you select the plain strategy to be “average symmetrized BRDF” you can render without any uv maps associated to the geometry
Just trying the scans with the trial - really love the results, but a triplanner mode would be hugely useful - especially suited to the nature of the materials.
well, apparently the triplanar mapping is working only with textures, no chance to make it to accept our material, at least from our side.
however we can add the same functionality in the “plain material strategy” options
my last info is that the nightlies are frozen or something like that, i.e. only explicitly selected bug fixes are transferred to the build system, and this does not include the triplanar mapoing or other features.
I’m running the nightly build from today, OS X Maya 2016, I don’t see any triplanar options for the scanned material, an I not looking in the right spot?
i think you are runing stable nightly, it includes critical fixes, but not the new features. but if i’m wrong and you have master nightly, the triplanat should appear in the “plain material strategy” option
yes, the latest nigltly is from june, the stable builds are running, but they are not including new features
of course, at some point we will restart the nightlies, i think it’s not so far in the future.
So to get the triplanar scans, I’m still confused as to which one I need to download. The only thing I see that has a current date on it, are the stable builds.
I tried using triplanar with car paint vrscans but I still get strange dark areas. are there materials that work better than others or is the feature in general not yet well implemented? (using vray next beta 2, nightly from today)
