VRayVolumeGrid long render time with enabled camera motion blur
When I render VRayVolumeGrids with enabled camera motion blur render time increase significantly, x13 times (1.5 minutes versus 13 minutes). Is there a way to speed up renders of VDB sequences with motion blur?
Use bucket renderer.
Enable the volume grid light cache (separate from GI light cache) and set the light cache speed up as high as you can get away with (it causes flickering the higher it gets). Usually 0.3 or below for production, but with fast moving stuff sometimes you can go higher even. Leave this on and set very low (0.01) if you still get flickering. Just being on at all is faster usually.
If you must use progressive renderer for some reason then disable the volume light cache.
Try increasing step size, and especially shadow step size as high as you can get away with (can and often should go higher than 100%)
Not sure this makes a difference here, but a VrayCamera can be better than a Max camera.
I usually do not use volume grid light cache because I found my render times are even higher with light cache enabled. I will try VrayCamera. Thanks!
That usually happens with the Progressive sampler. Normally with the Bucket Sampler it is much faster. But YMMV; it does all seem scene dependent.
I would say with the volumetrics especially, you rarely need more than 1 for the Min Samples (general AA settings). Of course you may need that for other elements in the scene…
