Hello!
The “Archive” function no longer works. Assets are no longer copied,
even when using Archive as ZIP. Is this a known issue?
We use VRay 5.20.02
Thanks!
Hello!
We use VRay 5.20.02
Thanks!
Both Archive and Archive as ZIP work fine on my end. Does it happen in a specific scene?
Is the export related to the ChaosCloud? Two hours later it worked again.
Not directly, no.
During the export, ccloud.exe is always started. When I then logged into the cloud,
something said that it was currently not available. Hence my question.
Ah, okay. Well, it’s just that the Archive functionality utilizes the ccloud.exe (so there is some relation, pardon my previous post). The cmd window should close automatically after the archive process is complete. There’s nothing to worry about.
