OK. I downloaded the MediaInfo app to identify the codec that Enscape uses…
Enscape_2021-03-04-11-42-30.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/mp41)
File size : 134 MiB
Duration : 13 s 684 ms
Overall bit rate mode : Variable
Overall bit rate : 81.9 Mb/s
Writing application : Lavf58.49.100
NOTE: Codec ID is “isom” which I do not recall seeing before… maybe this is something the Enscape Dev team can address… Use a different codec ID OR compression library to export the video…
And here is VLCs info as well:
I wonder if the Codec identifiers on the resulting MP4 from Enscape are causing Windows to not be able to select the correct codec/hardware acceleration and thus the video looks choppy…
I installed a few different codec packs including LAV, KLite, XVid… none played the Enscape MP4 file correctly in Media Player or the “Movies and TV” app…
Downloading a 4k 120fps mp4 test file from a link in the description of this YouTube video (large file) plays smoothly with the codecs mentioned above:
Those GB sized videos played just fine…
035A1382.MP4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/hvc1/CAEP)
File size : 1.83 GiB
Duration : 33 s 567 ms
Overall bit rate : 469 Mb/s
Encoded date : UTC 2020-07-12 07:24:22
Tagged date : UTC 2020-07-12 07:24:22
