water became transparent when enable Aerial Perspective
as the title said, there are conflict between water material and Aerial Perspective, scene attached.
win10, houdini 19.5.551, vray_adv_60021_houdini19.5.534_63d42af_22320_windo ws
try to use fog as substitute , same problem.
tried volume object , same problem.
water and aerial perspecive conflict.rar (64.3 KB)
Hey @len_xie ,
Giving the geometry thickness (e.g. by poly extruding) will resolve the issue in the current scene. I’ll check with the developers to see if there is a way for us to handle such cases automatically - it seems that the first refraction hit is ignored when a volumetric is intersected after it.
Best regards!
