Hello guy,
I need a little help.
How can we do this shader? The blue water.
I tried different way, absorption, refraction color but no good result.
The lake ground is, obviously, brown dark, and there are some SSS in the water, I think.
Refraction, colored absorption and Bidir/VCM, did you try this?
Hi.
Maybe this tread help you. Is water pool but get the idea:
Best.
PO
Great solution Maru!
It’s not great. It’s crappy. For example objects than intersect with water surface will also make those “contours”. But it’s the only solution I could come up with and maybe it will be useful as a temporary workaround.
it would be much better when I add distancemap shader
I tried googling it but still not sure, is it something like volumetric fog in games?
