Is this a bug or am I missing something ? All the llights are vray with vrayshadows. Spots are standard with vrayshadows.
It´s the squares on the wall and cabinet-doors…
Is this with Light cache? Can you check if you’re using the new adaptive lights option? You can find it in the render setup window > VRay tab > Global switches (switch to advanced). Try switching it to full evaluation or uniform probabilistic. It will make your scene render slower, but it should work around your problem.
In any case, if it is possible, it would be extremely helpful to us if you could send us the scene.
We had an issue with adaptive lights in certain situations; this is fixed for the 3.50.04 update, but if you want a fix urgently, please email me to vlado@chaosgroup.com
Yes this is bf/lc and adaptive light. With advanced it is working but slower. Since this is gonna be animated to 8 different scenes speed is of the essence ![]()
I´ll email you for the fix…
The fix is working
Rendertime is exactly half with adaptive lights. Awesome!!!
That’s very good to know ![]()
I can´t get displacement to work with this version ? It´s freezing in startsequence
Looks like we´re running into the same problem with one project. When will 3.50.04 be released ?
On Monday I guess. Like I mentioned before, if you need the fix, please email me to vlado@chaosgroup.com with your 3ds Max version.
No, it´s not that urgent. But thank You !
