White border
I remember this being talked about before, but I could not find the tread. How do I get rid of the white border around my image? When I paste a sky into my alpha channel (PS) I get that white border. What causes this and how do I resolve my issue?
try photoshop - layer - matting - remove white matte. not perfect, but should be better than what you have.
as i understand, the white fringe is a result of the AA in your image blending with whatever the background is. maybe try rendering against a sky, even in you are going to comp a sky later.
just be sure to always render against black.
Exactly, try to adjust the overall brightness of your background to the future composition. I always put a corresponding Vray sky then I composite the sky with blendings on top of the vray sky, with the model on top of this, masked with his alpha.
Defringe works well with white/black alpha, but it’s a complete mess on gray alpha, so avoid it if you are using alpha for the glass parts for ex.
white border
I remember there being a setting when I open up in PS. I was saving as a exr, which had this button, but since I started using CS3 I stopped using exr’s because they were not opening the same.
most likely glorybound, you just needed to reintroduce the proper gamma. Unless I’m way off from what your saying.
