I just installed vray 3 and max 2015 and am doing render testing. I’m getting random white speckles in areas where there should be no speckles. I thought I had seen something on the help files about how to get rid of them but I can’t seem to find it now. Any suggestions.
mh
enable max ray intensity and try a value of 15 or so?
If the max rays intensity doesn’t work try going in to the material editor and select the material that is producing the specs and under the options tab change “Treat glossy rays as GI” to “Always” that should help as well to reduce or eliminate the specs.
-dave
