white spots in render
how do i get rid of these? i’ve already turned on ‘clamp output’ and ‘sub-pixel’ under color mapping.
Re: white spots in render
Double check if you have enable reflective GI at the Indirect Illumination option. If yes, disable it.
Best
Those are not the same spots that “clamp output” and “sub pixel” would fix. That is something different. Im guessing your using irradiance map?
hsph. subdivs in IM rollout to low maybe? Just a guess
Hi
May be this post can help you.
http://forum.asgvis.com/index.php?topic=5833.0
this happened to me before and i found out that my caustic is on enabled. i turned off caustic and they are gone.
physical sun
and, how to sove that?
I’ve tried pretty much everything you’ve told me. Nothing works. Here’s my settings. Any ideas?
Hi Vise
Can you email me the scene and the textures ,if you are using textures, to fpedrogo@asgvis.com to look at it.
Best
Hey Vise,
If you have refraction layer on the glass make sure you checked Affect alpha and Affect shadows, under the refraction settings menu.
Thank you! That is it! It’s fixed :slight_smile:
I knew I could count on you guys.
which solution solved it?
this one
