Do you watch the effect of the downlights?. And the effect of the lamp?. It’s true that through the aperture of the right there are no light beams but yes, there are ambient light enough.
What should I do? What do you recommend me?:
Increase with higher power the “normal” lights of the downlights and lamp and decrease significantly the ambient light of my Corona Sunlight system and all this combined with the highlight compression setting?.
If this is something that could be reproduced using photography in real world, then it should be also possible in Corona. You can try increasing lamp’s intensity, and/or decreasing sunlight/skylight intensity, just try not to exceed realistic values…
From a photographic point of view I hate mixing indoor lights with outdoor sun/sky light. What you end up getting is a mix of color temperatures (blue daylight with yellow tungsten) and it’s a nightmare to balance them out. Just my two cents.
As far as reality goes (mind you I do quite a bit of interior photography), if the room’s got windows - lights turned on won’t make a big impact. Daylight is just too strong. It’s a different story when it’s in the shade, like the reference attached by the OP.
