If you are using a recent Nvidia driver + recent V-Ray build you will see a boost in performance in Cuda mode, we worked with Nvidia on this recently. And even on older Vray 5 builds you will have a nice boost, for example the benchmark tool will show you much higher scores than before.
So we are aware of that, and it is expected to happen, the difference will be small like what you see in your case
And on the other hand we are working on improving the RTX mode as well, it is also a priority to us
I do testing regularly on both modes, most scenes still show a performance benefit on RTX mode. Rarely do I see a case where Cuda is ahead, and it is usually a small difference like your case
@Paul_Oblomov Being 2 times slower than Cuda is not expected, I haven’t seen that.
Could you please share more information on your setup and Vray version. It will be helpful to follow along to troubleshoot this
Yeah, it wasnt, but I just changed to cuda and 2.49 became 1.07. Very nice surprise here. About debugging - maybe later. Scene is so simple, that I’m sure you have something like this through all the scenes, that vray is testing against, before release.
edit
But non of this matters, since a bunch of errors.
// Error: line 1: V-Ray : C:CIcgrepovraysdksamplesvray_plugins
t_private
t_opencl_(2765) : CUDA error 700 //
// Error: V-Ray : [MemoryManagerGpu::releaseUnmappedMemoryFromInstanc e] 700: Could not release device buffer //
// Performing AutoSave at 2021/10/19 16:57:02:
edit2
LOL. Now, while cuda is faster it has broken materials. Only slower rtx renders like it should. Vray gpu “almost_pre-alpha” 5 maya from today and latest drivers. Now cuda 4 times faster, tho with broken materials I dunno, is there any review tests scenes, before nightly goes online? Why my pc is the only one, that got some troubles with vray gpu… Feels like devs pc are just rock solid stable war machines from future. I wasn’t able to render anything, that is more complex, that two cubes with vray gpu in about a year or so. Curious, how others are rendering smth
I’m sorry to hear about your experience, are you using a 3080 ti by any chance?
We are investigating issues with specific setups, using LHR GPUs 3070tis and 3080tis and yes most of the complaints are on Maya’s IPR
About the testing, we have automated daily tests and I do my own testing with a bunch of production scenes of my own. I joined the Chaos team this month, prior to that I did concept design and 3D visualization in high-end print for about 6 years, mostly Automotive work and interior design
And yes Vray GPU is being used in production, I used V-ray GPU at Renntech, Carlex and bunch of other studios I worked at.. I will add that stability of V-Ray GPU is top priority to Chaos, and now I’m spending a lot of my time testing V-ray GPU in Maya
If you get a chance to test with my scene here , let me know if it crashes for you or if the RTX mode is slower than Cuda
Are you using a build from nightly or stable folders? what Maya version ? and what GPU and driver do you have?
Or if you get a chance to upload your simple scene, if it crashes for me I will follow along with you on getting this solved.. And same about the RTX slowdowns
Thanks!
Which is the newest nvidea driver for vray gpu, mine is 471.05, i did a test RTX is by far faster than cuda almost 40% faster than cuda in interior scene and exterior scene… RTX is very fast much faster than cuda no doubt, vray 5.1 gpu for sketchup
i don’t know why people complain about this, since the rtx release RTX is faster than cuda almost 40% or 50% faster, i almost don’t use cuda… 2 2080ti with nvlink is great with RTX mode
Well, my rig is tr24cores/3090/256gb. Always new drivers and fresh builds. I tried scenes from benchmark rtx with recent drivers and 19th build is faster. Tried my own scene - broken material in cuda and it is 4 times faster, than rtx. Magic Will upload scene today.
Newest recommended driver is 471.68
You can always go to the GPU page here, you will find the recommended driver at the top. Additionally you will find a message in the log if you have an old or newer driver than the recommended one
Thanks for the feedback, I have always used RTX mode when I worked in high-end print. That being said, both modes will evolve with time, they share most of the code
It depends on the scene, usually Optix is faster when you have hair/fur/grass. And in a rare case of being slower, the difference is small.
Both modes will evolve with time, we work closely with Nvidia on improving Optix and Cuda performance. Newer drivers are helpful for that as well
If you have a very good CPU, using Cuda makes more sense in that case. Other than that, I usually use RTX mode
Sometimes the GPU driver goes to this odd state, until you restart the machine or log out.
So this doesn’t crash for you anymore?
is there a chance I can get this piece of geometry/scene, I will test with both builds and let you know what is going on.
Thanks!
Definitely noticed a difference just today and up until now RTX always outperformed CUDA significantly so I had not tested in a while, I was so confused before reading this thread as to what was going on, like RTX cores were eating too much junk food sluggish i thought.
