I had working yersterday and since the release with it fine. i go to sleep, i’m wake up and now everytime i start a GPU render vray.exe windows show me : Error CL_Out_Of_Ressources (-5) at line 1947 , in file ./src/ocl_tracedevice.cpp !!!
the render is cut in some square where some are nearly black.
My Nvidia drivers crash, the recover .. then crash again and my windows restart …
My system is clean, i have reinstalled everything in a new fresh windowsSeven x64 on a new fresh HDD .
my nvidia driver is the 270.51 beta, the one wich make more Gpu working on cuda and opencl .
i have delete the *.clbin , but the crash occurs again .
Are there any other programs running that might be taking away GPU resources? If you run a GPU monitoring program like EVGA precision, does is say something meaningful about the GPU RAM usage? Also, what happens if you disable some of the cards?
with the help of “evga precision” and “choose openCL devices” i have isolated 2 card on my 6 wich seems to beeing in the issue.
this is not a software wich take memory .
the difficulty is that the card list order of “choose openCl devices” isn’t the same at the nvidia one.
So, with Choose opencl , my cards are 0 1 2 3 4 5 and the one wich seems in the issue are 1 and 4.
I’m back to the 263.xx Nvidia drivers wich working very fine. But the issue still here !!
i will try to replace the card to see if it’s an hardware fault .
I hope that’s not my card !!
