maybe someone know a solution for this card. MSI sells 3-slot bridges only?
Or would a 3-Slot Bridge work well too? Is the space enough between the cards for a solid cooling?
-Micha
-Micha
For this massive card, you have to use the 4-slot NVlink and you will still need very good airflow in your case.
the 3-slot bridge will choke your cards and they will throttle like crazy
they will throttle less with the 4-slot bridge as well, and depending on your airflow and if you have AC in your room
It will not show combined VRAM, this is only in Vray.. It should be able to use NVlink if you have SLI enabled
what about the log, where it says querying NVlink. Does it recongnize your NVlinked cards?
I think you should make a separate thread on this and upload example scene to support. Other people are able to use combined VRAM with NVlink for long time.
