wierd artifacts in animation
Hi all,
I am getting weird artifacts in my animations of this scene. Not sure if I need more samples in the LC?
I render out a small clip every 5th frame to show off what I am trying to explain. You can see it on the tables and the beams.
I am using BF and LC.
Thanks, guys.
Dropbox - Comp 1_1.mp4
Does it help if you turn on “Sub-pixel mapping” and “Clamp output” in the Color mapping section of the render settings?
Is this with denoiser?
So I tried turning on subpixel mapping and clamp output same results as before. Yes its using denoiser.
Do the original RGBs have these artefacts?
Yes they do
Can you show the originals? Because of the video compression it’s a bit hard to see what’s going on.
are you using lightcache for glossy rays.? if so turn it off and see if it helps.
Tried LC at 3000 and retrace at 8.0?
I did Ashley and still no luck
