2 things that i really miss in vray for this project are:
* not aliased Z buffer pass - as you can see there are errors in the DOF done in post in DOF PRO
* possibility for the dome light to show alpha channel
Anyway, C&Cs are very welcome, especially in this stage :))
In the first image, the DOF seems odd to me; i’m not sure that a result like that in the real world is physically possible, given the amount of the image you have in focus, the background probably wouldn’t be as blurred as you have it - just seems unnaturual! That’s the main thing that sticks out to me.
i know, i have changed the Z buffers gamma quite heavily…the images dont have to be physically correct, but i can understand that some people can feel its weird
anyway, what bugs me more is that the alliassed Z buffer has caused loads of artefacts not only on the opacit ymapped leaves outside, bud also on some objects right in front of the window glass panes.
Great Job, I love the lighting..they have a great natural feel to them. HDRI with Vray Sun ? lwf ? on 2.2. What Color Mapping ? Any insight would be great im working on my first Interior in a while today. =P seems like ive been spending all my time on exterior lighting lately.
What was rendering time for the first one ? If you dont mind.
hello Ruben,
its only lit by one of these HDRIs http://3docean.net/user/paguthrie/portfolio?ref=paguthrie
LWF, gamma applied in post, DOF and Chromatic aberation done by DOF PRO from Richard Rosenmann, Color filters and tints done usin NIK Color Effects.
Rendering settins are pretty normal, nothing unusual
Rendertime around 12 hrs on 3.6Ghz i7 quadcore, 12GB RAM…in some places the settings will probably have to be raised for certain materials
Hope this helps.
Nice. Thanks. seems like my same Exterior Settings so lets see how it goes. =P Sometimes it seems like i cant get enough light inside, however I also purchased guthries HDRI’s which seem to be lighting my Exterior far better. Lets see how interiors goes.
Nice renders! Nice feel.
When i looked at first image i thought it looked like a small/miniature model, but couldn’t work out why. I was thinking the furniture scales were a bit off, but reading on and taking a look again the DOF gives that effect. It gives a nice feel, and works well for close-ups.
What do you mean exactly ? You can have both anti-aliased (referred to as “filtered”) or non-anti-aliased renderelements depending on the “Enable Filtering” checkbox of
the renderelement. Mind you that anti-aliased (not aliased?) ZDepth doesnt really make sense usually as the filtering is not blending pixels but moving points in space.
been already in touch with Richard Rosenmann over the artifacts which come out when using “non-anti-aliased” ZDepth map in various DOF processors and i am working on some improvements.
the lighthing overall is lit well..
but somehow I found the 1st visual abit odd. the sliding door the frame isn’t it too thick and its make the leather chair look out of size. and the leather chair look like floating. I think Ambient Occlusion can make it better.
btw i love your wooden floor shader very nice. mind to share the setting for the material of the wooden floor hehe.
ooh ya..and the carpet!! very nice!! how to do that? displacements?
the frame is 7cm thick…which makes the part with tha sliding door 14 cm wide…there are many ways how to consctruct sliding door, maybe this one is not the most wise one i will look into that (client is happy with it though)…i can see your point here though! thanks
the chair size is fine, so ar ethe sizes of all the items in the room (ive doen that with almost mm precision :))))) )
leather chair floating…ill have a look, maybe bring it down a bit, but it should be stitting on the floor (the floorboards are tilted a bit so that might cause the floating gaps here and there)
i am not too big fan of AO in interiors
the floor is a multitexture material with 10-12 (cant recall) textures of wood planks, with random gamma, the same maps were used to do reflections and bumps (using color correction in max)
carpet is vray fur, you need to make the polys on the model the same size, otherwise it will spread the fur strands odly…after that its just a little tweaking
Thanks Pixela, yes the DOF is wrong co si have played with the DOF ZDepth gamma in post :)))
i also setup the DOF distances all the way from the camera origin to the end of the garden…just wanted to have a range to play with DOF PRO.
I will work with the DOF more properly for the final images
