wip tanker, thanks for your help guys!!!
hi there…
it’s a project i am working on right now, and apparently,
my sea sucks.
any idea how to make the sea real nice? i mean the wave.
i am using vray plane, and noise in the bump slot…
been struggling with the wave, no luck yet…
thanks
maybe use one of those see- pluginns like dreamscape ?
there also was a tool for things like this for free… dont know if it would do the job
Tom
stretch your noise in the bump in one direction to make it more like waves
great! let me try that~ thanks da_elf
Some ideas here http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=17959&postdays=0&postorder=asc&highlight=waves&start=0
that was a great plug-in… unfortunately, i am using max 9 here… sigh. by the way i was trying with displacement 2d, with an image i made in ps, not really promising though
I think you should try and find some picture that somehow matches the camera angle, and if possible the time of day.
It should be easier to match it up properly.
Big improvement, imho, from the first to the second picture.
You might try and add some bigger noise as a mask to some larger or smaller waves, and break up the repetitive pattern a bit, or to create some “flatter” areas here and there.
Lele
Try adding three or four different sized noise procedurals with the mix map thingy. Also add an inverted smoke map stretched in one direction (as per Da_elf’s post). The more variation the better.
i stretch it by going as low at 0.1 or lower sometimes in the u or v slot of the noise tileing
latest attemp… thanks all, you guys really are helping :slight_smile:
by the way, this waves make my ship looks small. maybe i should scale the waves even smaller…
You’d have, well out at sead, 2 main components to the waves: the big swells and the waves you’re working on now.
Try adding these swells, the “hills” of the sea, and see if they return you some more proper scale.
You could probably just displace (or even model, what the heck, they’re just a curvy, regular shape) the swells, and leave waves as bump.
Add a depth fog, too, that will help with the sense of scale (ya know, big sea, far distance, water vapor…).
Getting there, by the way.
Lele
well, thanks everyone, i am running out of time, and this is the latest attemp, i am quite happy with it, have to give to client for approval.
:slight_smile: cheers
The latest water looks good, you could still benefit from scaling the water down…still get the scale model boat feeling..
Could be down to the lack of details on the ship, and the chains on the front of the ship also look out of scale..
-Tom
i’ll do your suggestion,
i think the chain is a little bit bigger than the original.. almost 2 times bigger … well, need to amend that. thanks for the comment
very-very nice!
good work!
u don t stop do u? :lol:
no enexis, unfortunately i can’t stop… really can’t… hehehe… how am i going to eat if i stop man? heheheh :lol:
:smile:
u need to charge more for ur work then!
:lol:
quality and speed must be payed in the end also! :wink:
heheheh they pay me good alrite. :smile:
thanks for the concern enexis, appreciate that!!!
:smile:
this is the latest one… hope they like it, and you too!! :lol:
i know this is abit run from the reality, but i am looking for a
dramatic visual, i hope i am going the right path!
thanks again guys, really appreciate your help!!
