seriously though, speaking as an architect who moved to visualisation, it never does any harm to politely remind your client that you are the one with the expertise in knowing where to position the sun.
In my experience the most problematic area is in composition, the architect always wants to show more than is needed!
hello,
I think the roads need more work adding lines…the car in the frontground looks like is driving fast inside the parking lot…even if you have to fake it, I would put a curb on the botton left corner to have a sense of direcccion
maybe different asphalt color would improve the image.
Here is an update. I am not sure it’s going to move anyone, but it is what the architect asked for. Anything that would help make the image better would be appreciated.
It looks better!! I think the grass is too dark, the big tree in the middle doesn’t look right… Usually, between roads with that width, it should be something in the range of 10’ to 15’ height.
I think your final image on page 3 works really well, the shadows from the trees give it much more depth. Can you tell me how you achieved the wet road look on your previous versions? Is there a good tutorial you’ve found? I rarely get to do exterior renders but would like to play!
The closeups don’t look that good as the main view…the scale of the EIFS are off and TM looks like it has been added in photoshop…maybe i’m wrong but it doesn’t look in perspective and the brick map looks like is in low res.
How’s the overall brightness? The architect said that it is way to dark, and I am assuming it is his display, because it looks good on all my machines.
