Wish: 360° spherical panorama image output
maybe it’s possible and I doesn’t found the right options. I would like to save 360° spherical panoramas in PNG format for VR tour usage (like for Pano2VR). Is it possible? If not, please add it to the wishlist.
-Micha
You can save the panorama as a plain image file if you double-click the panorama image or you left-click the “…” button and select “Save panorama to file …”
Can’t say anything about the formats Pano2VR supports.
Thank you, found it. I have overseen it. Could be nice to add the two hidden features to the button line.
I rendered at highest quality - looks great, nice detailed, also small details are shown.
I ask me, where can I set the resolution to a specific count? In the past I rendered my projects at 10.000x5.000 and I would like to keep this size.
During the long calculation I got the impression the same regions are rendered again and again, there seems to be big overlapping areas. Maybe it can be optimized, since it looks like it cost a lot of render time.
The panorama resolutions are fixed to values that run more efficient on mobile devices and browsers. It should be easy to scale them exactly with an image tool if you really need that.
Thanks for the suggestion on making it faster. We already did a lot there, you will see in v2.1, it will render much faster!
More speed sound great. I’m very curious. :slight_smile:
I would like to avoid upscaling and deliver the quality my clients like. Panos are great for PC use, for example since years I use Pano2VR to create swf flash files for presentations. My clients like it. Current Enscape allow to render only max 8192x4096. More freedom could be great. :wink:
@Micha Everyone loves freedom, that’s why we have it on our agenda :wink: Got your upvote
Great, thank you.
