Wish: Rename layer of frame buffer controls
it would be great if correction layers could be renamed. Please add the possibility.
For example I need to render 5 views of an interior and each view needs an own fine adjusted exposure. (I like to keep exposure states for later rerendering.) At the moment I can add multiple exposure layers, but can’t change the names.
-Micha
:slight_smile:
Yavor
It’s not working here - not per double click or context menu. I use VfR version 5.20.04. (4.2.3).
You can type in the edit box in the properties panel.
I got it. :slight_smile:
Thank you very much, Yavor.
Welcome :slight_smile:
