hello everyone, just would like to find out whether anyone knows where did the raytracing global options go in the render rollout…as i need to disable “show messages”…its not present anymore in the new vray render rolout…or should i be looking for it somewhere else?
big thanks
ah found it…had to switch back to max default scenline and turn it of…then switch back to vray ![]()
You can switch to the Active shade renderer for a moment; you will get the Raytracer tab which you can change as you wish. Then you can switch back to the Production renderer.
right …good hint vlado cos when i swith to max rendered i loose all my vray settings ![]()
thanx
regards
martin
