I’m currently trying to render an animation with corona. On the renderfarm corona always uses the focus distance value of the last frame in the animation. This means all frames are heavily blurred. A test on a single machine showed that the correct values are being used, but it always crashes Cinema4D after 1 or 3 frames. I’m using R16 btw.
So I’m currently stuck between rendering the full animation with a fixed focus distance and loads of crashes. Is this issue known and will there be a fix or is there even a workaround?
Thx,
B0
