I’m an absolute technical novice when it comes to anything inside the PC Case.
I’m wondering if this RAM - Corsair Vengeance LPX Black 128GB 3200MHz DDR4 Quad Channel Memory Kit LN106344 - CMK128GX4M4E3200C16 | SCAN UK
Would be compatible with an Asus Rog Strix X299 E-Gaming? - the details for which are in the attached screenshot
Hi Dave,
From what I can tell, that memory will be compatible with the MB (https://pcpartpicker.com/products/memory/?compatible_with=n7VBD3) - PCPartPicker lists that exact memory as being compatible, although it doesn’t technically list the 128GB option - assumably because it doesn’t have anywhere that sells that combination in its database currently?
I also had a look on the MBU manufacturer spec (https://rog.asus.com/uk/motherboards/rog-strix/rog-strix-x299-e-gaming-model/spec) and it does support up to 256GB memory so can’t see why it wouldn’t work.
Whether that memory is the ‘best’ one going is something that’s beyond my understanding - CAS-latency and memory timings is too confusing.
