Is there a preferred method of using vray proxy objects (for many trees for example)?
Should I ‘Xref-in’ the tree proxy from an separate max file? Or, should I Merge the proxy file itself in directly? I am curious if they are the same or is one method better for memory, file loading, render times, etc.?
