cloud does not work at all
  • cloud does not work at all
    Hi, since yesterday evening i do not have any reaction when hitting the cloud button, just from one moment to the other, installing the latest cloudinstaller several times does not help. I have tried different .skp files, restart everything and so on. Exporting a vrscene works fine, local rendering as well. Any problem on your side?
    Latest version of vray next and sketchup 2020 on a mac.
    vbr
    be
    Currently everything is fine on our side. Can you please let me know from where you start the Cloud button? Do you go through the Asset Editor? Or do you use the Cloud button from the V-Ray toolbar? Or both? A screen-shot will be of great help.
    Thanks,
    Vladie
    Vladimir Dragoev
    Product Specialist
    Chaos Cloud
      I am having this issue lately in Vray for SU. Click the cloud button, bottom left corner says initializing Renderer, then Parsing Geomertry, then Building Scene, then goes nowhere. Any Ideas?
        Hi AMG445,
        Can you please answer the same questions: Can you please let me know from where you start the Cloud button? Do you go through the Asset Editor? Or do you use the Cloud button from the V-Ray toolbar? Or both? A screen-shot will be of great help.
        Thanks,
        Vladie
        Vladimir Dragoev
        Product Specialist
        Chaos Cloud
          Hi there, I have tried both - there's nothing to take screen shot of as nothing happens, Cheers, Nick
            Hi AMG445,
            Can you please help with answers to these questions which will help us investigate the issue further:
            1. Can you please share which version of V-Ray you have installed? We used to have such problem before but it was fixed in the latest versions of V-Ray Next and V-Ray 5.
            2. Are you able to start the Chaos Cloud client app in stand-alone mode? You can start the application from its installation folder here:
            Windows Default Install directory - %appdata%\Chaos Group\Cloud\Client\ccloud.exe
            macOS Default Install directory - /Applications/ChaosGroup/Cloud\Client/ccloud
            3. And another request - can you please before pressing the Cloud button open the VFB window and press the "Show progress log" button in the bottom right corner? Then please press the Cloud button and let us know what happens.
            Thanks,
            Vladie
            Vladimir Dragoev
            Product Specialist
            Chaos Cloud
              Hi there Vladie, thanks for the reply -
              1. I am running 4.20.03 - I can't upgrade to 5 as 5 will not render SUPlants for some reason (and I use these often)
              2. I have attached a screen shot - for future reference what do you do after you launch this?
              3. I did this - screen shot attached, and funnily enough after a couple of minutes it launched chrome and worked - so I have got no idea (it wouldn't work at all the other day)
              So I am not sure what is going on now? Cheers, Nick
                Hi AMG445,
                Thanks for the follow-up! If you can update to V-Ray 5, that'll be great as I believe the issue is fixed there. But meanwhile you can use the workaround. Sorry for the troubles.
                Bests,
                Vladie
                Vladimir Dragoev
                Product Specialist
                Chaos Cloud
                  Hi there Vladie, I am now running the latest version (as of this morning and am having the same issue. I can't render using the Titan (RTX) - it will only render in CPU mode. It was rendering fine last night but not this morning. Please find 2 x logs attached, Cheers, Nick
                    Hello, Nick,
                    Are you able to use the RTX GPU engine for rendering a new SketchUp scene or does the issue occur only with specific projects?
                    If a new empy scene renders fine, please submit one of your projects for investigation at https://www.chaosgroup.com/help/cont.../scene#options or via a file-sharing service of your choice.
                    Kind regards,
                    Peter
                    Peter Chaushev
                    Let's keep in touch
