vray toon
  • vray toon
    is there a reason why Vray toon does not render the same over the cloud as locally ?
    The attached sample shows my local render on the left and the cloud render on the right. As you see the cloud render has only applied the white 'toon' lines around the outside edges of the white building blocks where locally all corners (internal & external) are marked with the white 'toon' line.
    Hi 3dartvision,
    Sorry for the inconvenience with this job.
    This is a known issue to our development and it's reported as VMAX-8020. Can you please share the Job ID of this job here or in a direct message to me?
    Viktoria Dimitrova | chaos.com
    Team Lead, Cosmos Asset Creation
      not sure where to find the job id ? it is a current project that is currently busy on the cloud.
        The job ID is found in the Chaos Cloud's URL of the web interface when the Job Details page is open. See here:
        https://docs.chaosgroup.com/display/...HowtogetaJobID
