is there a reason why Vray toon does not render the same over the cloud as locally ?
The attached sample shows my local render on the left and the cloud render on the right. As you see the cloud render has only applied the white 'toon' lines around the outside edges of the white building blocks where locally all corners (internal & external) are marked with the white 'toon' line.
