Issue with color blocking inside Chaos Cloud but not showing on local render
  • Issue with color blocking inside Chaos Cloud but not showing on local render
    I hope someone can help, This just started happening. I'm getting blocking out of Chaos Cloud renders. See blue boxes. There are other areas that are more subtle in the salad texture.
    This material is built with a blend material. A solid for the bag, a transparent for the window and a translucent for the top and bottom seals. I realize I have some overlapping geometry in the seals.
    The solid packaging was rendered locally on my machine but I like to render all of my work through the cloud for speed.
    my masks are black/white and my previews are fine and just determined that my local render is fine.
    masks and all linked images are connected. I thought it was a checker from a missing item but no dice.
    I'm using 3ds Max 2022 and V-Ray 5 update 1.1 (5.10.01build 00002)
    Thanks very much.
    Jarrod
    Hi jarrodw,
    Is it possible to share with us the scene including all the assets so we can check what leads to this issue? Please use the Contact form and don't forget to mention this thread or my name.
    Note that you could also preview the scene using the Scene Analyzer tool in V-Ray for 3ds Max to avoid discrepancies between your local render and Chaos Cloud - have a look here.
    Viktoria Dimitrova | chaos.com
    Team Lead, Cosmos Asset Creation
      Thanks, I just uploaded a file with that geometry with texture, a camera and 2 lights. Hope this helps me resolve the issue.
