Yes, Chaos Cloud supports both RTX and CUDA and we respect your selection from the V-Ray settings in the host app.
Bests,
Vladie
Thanks, just curious to know though why there is such an option. Assuming that you do not need an RTX enabled GPU locally to render RTX on the cloud, why would anyone wish to upload as CUDA on the GPU if RTX is much faster? Or does CUDA on the GPU also use CPU on the cloud as well?
We found some small differences between the results of CUDA GPU and RTX, and want to make sure clients get what they expect.
We also have a separate CUDA CPU option to render only on CPUs. This option is useful if there is any issue with the GPU cards and can't be used, or the memory of the GPU cards that we currently use is not enough to render the scene on GPU.
