simple interior
Really nice work! There's just something about the sofa that doesn't look right - perhaps a bit more texture to it would help, and have the cushions a slightly different tone. The lighting is spot on.
Nice rendering,
(nice flowers on the table too)
one thing is wrong: the plant on top sticks through the ceiling
since I am currently working on a scene with similar approach (only skylight and direct light) can you mention your color mapping settings and light colors / multipliers?
ThanksYou can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
nice work! Can the TV be beveled a little bit?
thanx to everybody,
- yes, the sofa would be better with a texture (the same for the carpet) but the designer loves everything with clearly colors.
- yes there is an error with the plant near the celing
- the vase and some other furniture come from evermotion, ultra3d and (maybe) e-interiors
- the model is in mm (I tried in cm and the light result is a bit different...I don't know why)
no glass on the windows
direct light (RGB= 255,237,197) with multiplier=2
sky (RGB= 236,240,255) with multiplier=1,6
Primary bounce 1
Secondary bounce 0,9
IR for primay bounce with preset High
HSph 50
Interpolation 20
Light cache for secondary bounce
Subdivision 1000
Sample 0,01
Scale screen
Pre-filter 60
Filter None
Glossy with light cache and number of passes 5
Color mapping Exponential (dark=7, bright=7)
These values probably aren't the best to lighten the scene....so keep it like an example. If you have time, optimize the settings.
bye
fabrizio
I was going to ask how you got such depth and contrast out of LC, but I see that you used IR+LC. Makes sense now.
I'd love the speed of LC with the look of IR. Is that too much to ask?
What was render time?sigpic
J. Scott Smith Visual Designs
https://jscottsmith.com/
http://www.linkedin.com/in/jscottsmith​
http://www.facebook.com/jssvisualdesigns​
Why did you choose for such a high prefilter for lightcache?
wouter
Hi Fabrizio,
Very nice work!
Just 2 things i don't like too much. First one is the light in the corner, could be more smooth , second is that curtains are a little bit too much lighted .
It is my taste of course.
Cheers,
MarcoWorkstation Core i7 6900 - 32GB RAM - GeF970
Dual Xeon E5-2630 - 32GB RAM
hi tutanmark
I agree with you; the curtain is very bright...but i had few time to optimize light settings and materials. For example in this scene the floor seems plastic and not wood.
Moreover to speed up settings I removed glass and curtain.
These images were for a little work with a very little payment....
bye
