Twin Cabins
  • #16
    you camera is too height i guess, may be it just me..but i like the exterior one very much, good job!
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    • #17
      Try turning adaptive lights and/or adaptive dome ON.
      It will speed things up for you, even if you're using a dome light only.
      I Love the exterior by the way!
      PS. V-Ray dome, in my experience it's faster than Env slot.
      Regards,
      Ledian
      • #18
        Also, make Post Effects Update Rate 0 (Zero) when using production mode (specially if you have one gpu only).
        Regards,
        Ledian
        • #19
          Originally posted by fixeighted View Post
          Where is it from? The hdr I mean...
          https://hdri-locations.com/
          Bobby Parker
          www.bobby-parker.com
          e-mail: info@bobby-parker.com
          phone: 2188206812
          My current hardware setup:
          • Ryzen 9 5900x CPU
          • 128gb Vengeance RGB Pro RAM
          • NVIDIA GeForce RTX 4090 X2
          • ​Windows 11 Pro
          • #20
            You mean for my interiors?
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
            • #21
              Here is the living room with the new HDRI using GPU/hybrid - 4K in an hour!
              This interior image is amazing. Did you used HDRI in Vray Dome Light or in Enviroment slot?
              http://renderus.com/
              • #22
                Thank you. The HDRI is in the VRay Dome light.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #23
                  I lowered the camera and turned on DOF.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                  • #24
                    On the first one, I am seeing a lot of green on the walls and ceilings. I'll put a gray gi wrapper in it.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #25
                      if you drag that hdr into a material slot you can adjust the green level by enabling color map option then switch from mono to rgb and decrease the green level
                      • #26
                        Some updates on the bedroom and bathroom. I am not sure what's happening in the bathroom mirror reflection. These are using Hybrid rendering and it doesn't happen in CPU rendering.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • #27
                          Looks like a Denoise issue... Do you have V-Ray denoiser on those?
                          Regards,
                          Ledian
                          • #28
                            I didn’t check that, but I will.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #29
                              Wasn't Denoise. Vlado is looking into it.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #30
                                Are their HDRIs unclamped? Try looking over at HDRI-Haven for top notch HDRIs.
                                Website
                                https://mangobeard.com/
                                Behance
                                https://www.behance.net/seandunderdale
