Yeah, much nicer
Although I had some good results with similar towels using some fur, which could be used on that closer one on the right for added fluffiness
if you drag that hdr into a material slot you can adjust the green level by enabling color map option then switch from mono to rgb and decrease the green level
Do I drop the left control point down slightly? Basically, adding red?
