Twin Cabins
  • Twin Cabins
    This one, I had to finish in Corona. All the spaces went well, except for the bathroom mirror shot. I was getting strange artifacts that I was told is fixed, but not released yet. The bathroom in Corona went so well I decided to try the other views and, let me tell you, it went smooth. These will end up being an animation, so I eventually have to bring it back into NEXT for GPU speed.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    And here are the exteriors, which I posted awhile back.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      The interiors look good but (and it difficult to see correctly due to the small size of the images) some of the exterior context doesn't seem to match correctly both in perspective and tonally.
        I spent a month asking for photos they wanted me to use and these are what they came up with.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Here is the image they sent.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            I requested a high-resolution. I can't image all they have are thumbnails, but that's what they sent. I am hoping to get high-resolution before I do the final animation.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              It's difficult when they do that, hopefully they will send the high res photos but either way, I would suggest rendering the interior and exterior on separate layers so you have more freedom in post.
              As you already have an exterior environment, could you render a dome of it and render the animation cameras twice - one for the interior and the other for the exterior?
                I haven't done animation for a long time, so I want to keep it simple.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Hmm....isn't it worthwhile to make a 3D environment for them? Would look way better for sure. Then as the above poster suggests, just render your own spherical image to speed up the animation
                  Sad that clients can harm their own image quality by a lack of input anyway.
                    What's the best workflow to get the Backplate to look realistic except for actually modelling the exterior environment?
                    Add Your Light LogoCheck out my tutorials, assets, free samples and weekly newsletter:
                    www.AddYourLight.com
                    Always looking to learn, become better and serve better.
                      This is basically a 3D matte painting - there are many many resources online.
                      Using the example of a standard arch vis interior animation, the best way in my opinion is to create some basic geometry for the ground, tree line, fences etc.. render out the middle frame of the camera path if the camera is moving in a slow linear track. Paint it up in photoshop and map it back onto the geometry and render it out as a pass that can be comped in post similar to how an image is created in layers in photoshop.
                      If you don't or can't model anything to represent the exterior environment then create it in photoshop and do a 2.5d track in AE or whatever comping software you use. If the camera moves alot then there may be parallax issues which can be dealt with by splitting the environment up by distance eg. trees in foreground and background and mapping those onto different planes. In AE you would move and scale the planes away from the camera whereas in Fusion or Nuke you could use the 3D environments and map the images onto planes.
                        oh my god hopefully they can accept the down grade version for final render.
                        Jackie Teh
                        3ds Max 2023, V-Ray 7 Update 1 [7.10.00 build 00000]
                        AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
                        Website: https://www.sporadicstudio.com
                        Email: info@sporadicstudio.com
                        YouTube: https://www.youtube.com/c/SporadicStudio
                          We settled on a full 360 equirectangular panorama image from Shutterstock, which worked and looks great.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Looks good. Did you comp it in or is it on the scene as a plane or so?
                            • #15
                              Environment slot as a spherical map.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
