120 N.Fir
  • 120 N.Fir
    This is an infill historic renovation in the middle of a historic commercial district. The project has two units, A and B. This is Unit B. I am starting on Unit A now. It's looking out on a narrow alley full of old sheds, back of buildings, parked vehicles, etc, with mountainside beyond.
    I had trouble with the vrayReflection render element. It seemed to save inverted. it's mostly white but areas like much of the sofa, the recess lights and highlight sides of the windows are black. The vray specular render element saved out properly. I am not doing anything different than usual, not sure why the vrayReflection element is like that and basically not usable.
    Any and all comments and suggestions for improvement much appreciated.
    mark f.
    openrangeimaging.com
    Max 2025.2 | Vray 6 update 2.1 | Win 10
    Core i7 6950 | GeForce RTX 2060 | 64 G RAM
    I have been complaining about reflection in V-Ray NEXT since day one. The scene is nice, but it is kind of dark. Have you tried Camera Raw Auto?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Thanks for your comments Bobby.
      Agreed it's kind of dark. It is being lit by only a vray sun/sky. (I don't seem to need vray plane lights set to skylight portal at each window any more. Is that a thing of the past or do you still place those in your interior renders?)
      I was struggling to keep the highlights from burning out and so consequently...kind of dark. I'm trying it with HDRI/vray domelight now and it seems to be helping that issue. I will post an update later today.
      mark f.
        Yeah, the window lights are a thing of the past. I use HDRi's for my interiors, which when done right make an interior. It adds render time, but well worth it. I place trees outside my windows to block some light intensity when things get too bright. If things are not bright enough I put a gray reflector as a ground plate and I hide it from the camera.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I have an hdri lit version done and will post it here soon. I kind of went down a rabbit hole with it. It was causing some of the window reflections to get way blown out. any window that was not picking up the reflection of the back plate I have in the scene was rendering as white rectangle, not good. The window that is to the right of the large double slider door was the main problem. I ended up turning off affect reflections in the dome light. then I put a second copy of the hdri in the max environment slot and in the vray gi environment and vray reflection/refractions environment slots and adjusted the multiplier. That worked ok I guess. Is that what you do, separate the hdri that lights the scene from the environment?
          mark f.
            No, I just use an HDRI in a VRay Dome. I expose the camera properly and things usually work. I start off with a VRay Sky/Sun, expose that properly and then replace it with an HDRI and then I adjust the HDRI to work. I like to have a known base point first. Some HDRI multipliers are 1, 2, 4... some are 30, 40, 50... and some are 100. Make sense?
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Bobby, thank you for helping me with this. My image started with vray sun/sky and physical camera set to a good exposure same as you. When I went to change to hdri I think I was, in part, adjusting the camera exposure to compensate for the hdri. that was likely a big part of the probelm. I got so spun around using max environment, changing vray gi and reflect/refract environment to hdri and etc that now I can't be certain of what all I did....normal.
              I have updated sun/sky and my hdri versions ready to upload to this post. will do so momentarily. Thanks again for your valuable input.
              mark f.
                Here is the updated Sun/Sky version. All I really did was bump up the exposure in post.
                Below that is the hdri version. The main thing is I did not get the hdri rotated to match where the sun was. That is probably why all of the highlights on the metal fireplace, glass table, chairs and etc are not showing up like they do in the sun/sky version. Also the overall temperature/white balance is also different. I'd like to try getting the hdri to more closely match the reflections in the sun/sky, not sure i will have time for that but will give it a go on the next one.
                mark f.
                  Much better. One thing I do is look at my image as a thumbnail. Looking at it this way really helps me to see if the image is too dark. I also expose, ignoring my windows and re-exposing the windows in post. Not much different than an architectural photographer will do. They'll take at least two photos, one exposing the inside and one exposing the outside and merging them in post-production. On my HDRI's, I do have the V-Ray sun aligned to the hottest spot of the HDRI, however, I usually turn the sun off for interiors. For exteriors, I leave it on.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    For the interiors you do with hdri, what if anything do you have in the max environment slot? Also in the vray render setup environment dialog do you keep use GI and Reflect/Refract checked? Do you have any maps in those slots?
                    Thank you for your help!
                    mark f.
                      Nope, nothing in those slots.MAX environment isn't used, either. I just rendered this one out will all V-Ray NEXT defaults, using a V-Ray Dome using an HDRI. (sorry, can't uploads. I am getting errors).
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Bobby, this is very helpful to me.
                        I understand max environment turned off/unchecked.
                        In vray environment, nothing in any of the map slots.
                        Also in vray environment, do you have vray GI environment checked/on? Do you have vray Reflection/refraction environment checked on?
                        thanks again!
                        mark f.
                          Just the defaults. If you reset V-Ray and set to bucket, that’s what I do. I test with Progressive (change 1 minute to 0}, but finals are in bucket mode.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Thank you. Yes that is the same workflow I have used for quite some time.
                            I am asking about the setup when using a dome light with an hdri. How do you configure vary GI environment and vray Reflection/Refraction environment?
                            I “think maybe” when using vray dome light that it overrides and vray GI environment and Vray Reflection/ Refraction environment and both of those are disregarded by vray, but I have never been sure of that and don’t know where I got that idea.
                            Anyway I’m keen to know how you have those two settings configured when you use vray dome Light with hdri.
                            Thanks again for your help!
                            mark f.
                            • #15
                              still very dark. and does not look natural. to get the VRaySky into interior you need something more than VRay GI enviro. portals or VRaySky in the dome light. leave all environment maps and reflection planes out of it for now. get it right with VRaySun/Sky combo first. VRaySun on 1.0 and expose in the VRays camera.
                              Marcin Piotrowski
                              youtube
