Piotrus, thank you for your very helpful comments and advice. I did try to first get it right with just the vray sun/sky and a mid gray overide material as you describe. I increased the exposure up to where I started getting burn out in the hot spots.
I somehow had the understanding the skylight portals were no longer needed (wish this issue was more clear), so I did not place them in the windows. I'm going to do that and see if that helps. I have not tried putting the vray sky into a dome light. That's an interesting approach and I hop eto find time to experiment with that as well.
I think you are correct that because I am only using Vray GI enviro it's not effectively gettign the sky light into the interior. I will post an updated image here soon. Thanks again!!
