the green is the light coming through the leaves I would have to say. But I did fake the caustics on the tree bark in the foreground with a projector light.
Only crits are that it's a little unnatural the way that those middle trunks terminate. You should stretch them off frame. Also the ground leaves look so nice and random but the displacement looks almost too smooth.
Would be really cool to see some character animated through this scene
I also like that, if you look close enough, it's somewhat obvious the trees share the same texture but you really can't tell with that lighting
Ok, I guess I have to post a wireframe then.
The only thing about the trunks is that they all end in plants so I'm not sure you would see anything gnarly.
Rendering took I think 15-20 minutes.
settings: irradience, -5, -3
20 hemisphericals
lightmap 500
Welcome to the forum btw- nice to see another person living in Boston using Vray. Did you change your name from 'lgrohs' to 'maroomari' or is there multiple people working on this image?
actually lon is another guy that I work with, and I posted under his account because mine wasn't working. I'll get a wireframe for you guys tonight when I get home from work. thanks for the comments, there will definitely be more images to come. these images are fun to work on.
