8 Sweetwater
  • 8 Sweetwater
    Long time no post. Nothing special here, just my bread and butter work.
    Often, my clients want one or two views, and it is such a missed opportunity to get some detailed images. I ended up rendering some close-ups out. I had a real hard time balancing the white siding. Either it came off gray or over-exposed. Any tips? As usual, constructive criticism is welcome.
    Click image for larger version  Name:	8-Sweetwater---detail-1.jpg Views:	0 Size:	1.23 MB ID:	1146182
    Railclone for almost everything - it really slowed my viewport performance. Does anybody else have this issue? I would change cameras and wait 3-4 minutes for MAX to wake up. Turning things off/on in the layer manager caused the same thing to happen. It was frustrating as heck.
    Click image for larger version  Name:	8-Sweetwater---detail-3.jpg Views:	0 Size:	1.63 MB ID:	1146183
    A little too warm on this one. I was going for the warm afternoon feel.
    Click image for larger version  Name:	8-Sweetwater---front-2.jpg Views:	0 Size:	2.05 MB ID:	1146184
    This is one of the views my client wanted, but he had the sun behind the camera. I moved it to where I thought best and rendered it out again for my own pleasure.
    Click image for larger version  Name:	8-Sweetwater---detail-2.jpg Views:	0 Size:	2.06 MB ID:	1146185
    This is one in which the siding came off gray. I darkened the white slightly, but it made a huge impact. I like the contrast, but it is supposed to be a white siding.
    Click image for larger version  Name:	8-Sweetwater---back-2.jpg Views:	0 Size:	2.07 MB ID:	1146186
    I wanted to give the glass some interest, which I think worked with some noise. However, the center patio has too much noise, although it is the same glass as the rest. Usually my clients do not want curtains, but this client wanted his black window muntins to pop, and the only way I could do it was white curtains behind the windows.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    good to see your excellent work again! For the issue of the white siding - try adjusting the white balance. either in the frame buffer or in pshop with camera raw filter. hope that may help.
    i think that noise in the widow glass looks odd.... some subtle amount of reflected simulated surroundings might be better?
    Do Max and vray and everything else run OK on WIndows 11 for you?
    mark f.
    openrangeimaging.com
    Max 2025.2 | Vray 6 update 2.1 | Win 10
    Core i7 6950 | GeForce RTX 2060 | 64 G RAM
      Thank you for the kind words. Yes, I usually do some white balancing in PS. For the client's final, I did, but for these, I didn't. I agree with the glass.. a little overkill. I like the effect, but it needs to be a lot more subtle. The client thought seeing his mutton was of the highest priority, so i really cranked up the noise until he was happy. Everything is working fine on my laptop under Windows 11, with no problems at all. Again, thank you for the kind words.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Looks Solid to me Bobby as always!
          I think the bump on the glass is too strong, makes them look like cheap plastic. I'd do 20% of what you have, or so. And break up the texture so that the same pattern doesn't go from one pane to the next. each pane would likely have it's own distortion pattern, not one continuous pattern across them all. That would be my suggestion
          www.DanielBuck.net - www.My46Willys.com - www.33Chevy.net - www.DNSFail.com
            Yes, I agree.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              I think there needs to be a thread based on actual photos of things which, if done in CG, would look just plain wrong
              Purely out of interest of course, just to see how so many things in reality are just so un-aesthetic and odd looking.
              I have seen so many real-world instances of obvious tiling in materials, due to so many production methods being based on digital noise etc.
              I live in Bath in the UK and here there is a sort of law that says all the stone that is used in 'new-builds' has to match the existing
              sandstone.
              However, because of the lack of actual Bath stone (the quarries are depleted) developers, to cut costs, use cinder blocks clad with a composite
              or, more horribly, use cast sandstone bricks which look awful to me. They are meant to look like rough cut stone but clearly show repetitions.
              Here's one example. Hopefully you'll agree it's unpleasant.
              And yes Bobby, that window noise is extreme lol...but you know that, so all good
                It seems like profit prevails. If you can find a cheaper way to do it, they'll do it. I see tiling fake brick, stone, and shingles, everywhere. Here are some photos I took of a local park. I mean, the manpower that went into these structures. It seems like no cost was spared. What happened to architecture. I think it is sad.
ID:	1148266Click image for larger version
ID:	1148267Click image for larger version
ID:	1148268Click image for larger version
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
