nice, the vray ones are loads better looking....
Light Study and Gamma
Any info on the rendertimes? How many minutes did VRay render and how many days maxwell?
Dieter--------
visit my developer blog
render times...
well for flash render it was 5 min on dr, but that would be 50 min on single node
as to gi one, its qmc/lc with dome light at 100 subdivisions for noisless shadow, so it was 10 hours on dr, do the math your selves :P
however maxwell one wasnt any better. Maxwell has rendered similar image in 40 hours and it looked like it needed another 60 so...here you goDmitry Vinnik
Silhouette Images Inc.
ShowReel:
Hmm,
if I'm doing the math right the image rendered 100 h in Vray?--------
indeedthis is however is equivalent to ppt...so such result is not a surprise. However a part of the slow down in my first plastic - 1 shader which was made of 3 shellacs a big nono...I think if i translate this scene into normal vray mat which is plastic - 2 in my lib, then it will be a ton faster.
Dmitry Vinnik
ShowReel:
Hi Morbid, first of all: WOW, great renders... surely better than MW.
About that warm feeling, i bet it's the wooden parquet that do the trick moslty
Pls check your pm, i'm really interested in your "in depth" with VladoLighting & Rendering Supervisor
Marulli Studio
I'm still shocked with the rendertimes. If I would send out a frame this size that needed 100 computer hours to render someone here would probably slice me up and sell my meat in a plastic bag in canada...
Dieter--------
well I can tell you that I only allow such render time for a study. In production this is unacceptable, but unlike maxwell vray can do other things to render it faster, one of which would be irmap, the other bake. So if I actually had to render this in animation I would do a different approachDmitry Vinnik
ShowReel:
go on morbid, do the tweaks and render it nice n fast!
Here is the image that maxwell has rendered after 40 hours.
as you can see, it needs another 40 to get there
And here is also a study that I did to compare maxwell and vray. I have taken a scene from treddi forum where noob users tried to compare vray to maxwell and misurably failed...It is possible to get similar results in vray and maxwell.
Dmitry Vinnik
ShowReel:
whats the setup like in the for the vray example?
well the scene was quite specific, no sun/sky approach, rather plane sky color and emitter for sun. So I just manually matched the emitter intensity and rgb value for sky, used gamma 2.2 and ppt...thats all.Dmitry Vinnik
ShowReel:
here is a peak on maxwell vray shader conversion hack.
Dmitry Vinnik
ShowReel:
