beestee, which you do you think I should move the camera to improve the reading of the design?
DaForce, yeah I know the foreground sucks, the site is next to a busy highway and although I would love to place the building in its setting its going to be touch to get a photo, after all I am in Africa and the lions might chase me I will see what I can do.
Can you explain what you wanted to know with your question, how was it rendered?
All, Is it all my textures that need more work or just the flat looking plastered walls? What type of texturing would you use on smooth plastered and painted walls?
Maybe even just build up a simple kurb and some road. WIll help bring it to life.
The main problem with your textures is there isnt any (not that I can see) other than the obvious brick wall inbetween the green houses.
Heck even a bump or displacement map would help HEAPS.
You need to get plaster textures or brick textures .... something to put on that fence and on those light colored buildings.
You will also need a different background as the background shows the sun behind the buildings yet the sunlight is coming from the right.
