WIP Interior (Help With Lighting)
Tags: None
i would say your rendering is not too bad, especially for a first go. I don't think your lighting distribution is too far away, but i'd but your secondary bounces to 1.0 where it is currently 0.85 if you want to brighten it up. Also, to brighten it up, use LightCache as your secondary bounces engine. At the moment you have 6 secondary bounces using QMC - LightCache will give you all bounces.
Also IMHO - try some glossy reflections on the floor
SV,
Thanks for the reply. I will try out your suggestion.
MikeMike Henry
http://mhenry.cgsociety.org/gallery/
(DaForce) Yep, my background is starting to look a little like nuclear fall out.
(dominiquelaksmama) I agree, the environment color is off. I was planning on tweaking that a little.
Thanks again for the replies!
MikeMike Henry
