simple interior test
  • simple interior test
    Hi, this is simple interior scene, I used for LWF testing. C & C welcome
    mm
    Looks too perfect to me, too organized. Perhaps some chaos on the position of the chairs, just a slight one would be more appealing. Also the table stands very empty, maybe you can arrange a few flowers in a vase there or smth like that.
    But anyway, that's mainly personal oppinion. The image looks great anyway
      Wow, very nice indeed!!!
        verrryyyy nice!!!
        Dominique Laksmana
          Can some one please tell me why is LWF better the using Exponential Color Mapping.
          sigpic
            Go read the threads dude.
              cpnichols wrote: Well let me put it this way... do you use photoshop? I am sure you do or something that can in fact read HDRI or EXRs. So why not render in float then take it to photoshop and be able to adjust the exposure after the render? THEN save it as 8 bit if you want.
              http://www.chaosgroup.com/forum/phpB...=15303&start=0
                nice image, very clean.
                It needs a really nice lamp of some sort above the dining table
                Chris Jackson
                Shiftmedia
                www.shiftmedia.sydney
                  where is the test ... here is only one perfect image
                  looking very good
                  ARCHITECTURAL VISUALIZATION
                  www.projects3d.com
                    Your floor is incredible. Is that bump or displacement with glossy reflection? What are your settings for that material?
                    "Why can't I build a dirigible with my mind?"
                      Yeah i agree with cilfton, that floor is nice!!
                        lighting is perfect
                        can you tell us how did you light this scene?
                        http://www.3dvision.co.il
                          Stunning
                          This is stunning particularly the floor but over all, it is really excellent work. The exterior scene (I'm presuming a HDR of some sort -or other texture map) seems a little to close to the window, a great image overall, superb.
                            thanks for your comments. there is reference photo for this scene:
                            http://archrecord.construction.com/c...es/split-5.jpg
                            the floor material is vray material with glossy reflections, there is vray 2d displacement - I think it needs blend material for nonreflective gaps between tiles.
                            lighting - IRM -3/-1, LC 3000, linear color mapping, there are three vray lights in windows, stored with ir. map
                            exterior scene is just a photo, overbrighted and quick added in photoshop, you are true, now i can see, it is little bit close:-/
                            • #15
                              to get more detail in the shadows.. turn off "store with ir map"
                              I would never suggest using this unless your pressed for time.
                              Also LC @ 3000 seems fairly high for a single frame.
