First 1.5 render
  • First 1.5 render
    This was a fast project testing some of the new features.
    C&C welcome.
    Regards,
    Mike
    http://mikebracken.cgsociety.org/gallery/
    sweet, but is it me or does everything lean to the left?
      heh, it's not just you, i get a weird feeling of being on a boat from that picture....but the render is nice, very clean, almost too clean...
        i think the right side is falling away..........
        Chris Jackson
        Shiftmedia
        www.shiftmedia.sydney
          Did you camera correct and then change your mind about the angle?
          Nice render - good to see the sun/sky being used outside of a metal teapot/torus test.
            Do you think a 1.5 it's faster (or slower) than older version of Vray (1.47.03)?
            www.visumporec.com
              nice job. did you use the 2 sided material for the lamps and plants?
                Nice render. Yeah, it does look like there is a FFD 2x2x2 slanting everything to the left
                "Why can't I build a dirigible with my mind?"
                  Yes, camera correction then view change. I did overlook it. Ill call it
                  a boat.
                  Two sided mat on the shades. sun and sky, of course. Reinhard color
                  mapping.
                  The render time for this was under 20 minutes.
                  No TLC, just a quick (and lopsided ) test scene. Mostly I wanted to
                  see how the sun/sky looked in an interior.
                  Thanks for the replies,
                  Mike
                    Have you tried a version using the Vray camera with a little distortion, just to see if it really gets that photographic feel?
                      nice job Mike
                      Nice job Mike,
                      we try to acheive the kind of shadows on the carpet with a blurry effect ....
                      how did you do that?
                      thanks a lot
                      www.studioleonard.com
                        check his post, jo...he's using the new sun/sky
                        Talk nerdy to me...
                        Matt English
                        base2studios
                        VizDepot.com moderator
                          mapping.
                          What setting did you use for the Reinhard color mapping?
                          I am trying to get my head around the (pseudo) Linear workflow: that is using a colour correct modifier on all colour swatch based materials, having the 3dsmax gamma set to 2.2, and using vrays Gamma colour mapping with 1/.4545. Just when I got my head around all these settings and now we have Reinhard and real life cameras with f-stops and shutter speeds.
                          Kind Regards,
                          Richard Birket
                          http://www.blinkimage.com
                            I used a burn value of .75. I lowered all light values and used 2.2 curve. I also turned the gamma setting down to about .5 I think.
                            Shadows : I increased the size multiplier for the sun. I also put the vraysky into an output map with a 2 or 3 multipier to compensate for the very low sun settings.(I used a standard camera). I have been testing the physical camera, and have had much better results.
                            Regards,
                            Mike
