Sunlight Shadows
  • Sunlight Shadows
    How can I get the sunlight to cast sharper shadows through my glass?
    I have tried various refraction values but with little effect. The sun just seems to diffuse through the glass and you see no evidence of light falling into the room.
    I am using default sun settings and a Physical Cam 8 f-number, 125shutter speed & 300iso
    Glass is Vray mat - white diffuse, white reflect, fresnel checked. IOR 1.6.
    Any help appreciated
    Greg
    hello, you have multiple solution for this problem:
    1- use a standard material with low opacity
    2- select your glass objet right clic and go to properties and uncheck Receive shadows
    3- in your vray material check affect shadow
    Zahir3d
    PIXARCHI.COM
      Or go to the exclude section of your sun and take 'cast shadows' off all the glass.
      Theres a thread aout this at the moment.
        nice one guys i'll give it a go.
        ps. sorry for posting in the wrong place.
        Greg
          for more, look to this post : http://www.chaosgroup.com/forum/phpB...ic.php?t=15386
          Zahir3d
          PIXARCHI.COM
            something doesnt look right, do you have affect shadows checked in your glass material?
            Chris Jackson
            Shiftmedia
            www.shiftmedia.sydney
              I second that.
              best regards
              themaxxer
              Pixelschmiede GmbH
              www.pixelschmiede.ch
                yeah, in your glass material check the box "Affect Shadows" in the refraction group. Set a little fog color and the multiplier to something around .01. you will have to experiment with the fog multiplier as it directly relates to the thickness of the glass object.
